I recently installed the Slee ARB fog light adapter kit. Used the Baja LED fogs. One issue I didn't think about is the DOT reg that turns off the fogs if the high beams are on. Has anyone checked if Tech stream can change this? Any way around it? Obviously my intent is for offroad use as I run my HID high beams and the fogs are set quite wide. The combo would be perfect. Thanks!
