FNG
Norman, OK
Hello. I had purchased this 100 series couple years back from a work buddy. It was stock when i received it and well maintained at 185k. Back in the spring I decided to install the OME front shocks and rear springs along with the SPC upper control arms. Once I got into the front end, I went down a rabbit hole and ended up replacing the inter/outer tie rods, diff bushings, lower ball joints, CV axels, rack and pinion, etc. Put on new set of Method wheels with Yokohoma rubber. Slee blueberry v2 bumper with Warn Zeon 12s winch.
I am very happy with the way the build has come along. This forum has been a great resource.
Sweet ride. Did you feel like the ride got any worse when you did the bumper ? Did you lift the front end a bit as well ?
To the bumper did not change the feel for me. I did raise the front with the new OME shocks and Slee torsion bars.
