My other threads and their replies have culminated in a transmission on the floor. The clutch and throw out bearing definitely need to be replaced. But, I need some advice from a higher power on the condition of my dual mass flywheel. I'll do my best to describe what I have found:
1. The inner portion (section bolted to the crankshaft) is tight against the outer ring with no wiggle room
2. The inner most bearing that touches the transmission input shaft is in immaculate condition.
3. The friction surface of the flywheel is crack free with no signs of warping or overheating
4. The outer flywheel ring (part the the clutch contacts with) can be spun by hand about 1 cm clockwise while the inner ring stays stationary
5. Snap ring holding back the center section is in great shape
My questions are: Do the above characteristics warrant replacing the DMF?
Is it within acceptable tolerances for the outer portion to spin freely of the inner portion by 1cm clockwise?
Now that the flywheel is out, are there any particular things I should look for or do to determine whether it needs to be replaced or not?
*This is not my flywheel*
