I need to double check part numbers, but I saw in my shop last night I still have a new clutch and a (needing to be resurfaced) flywheel that Georg @orangefj45 sent along when I bought my H55F from him. Are these also the same flywheel and clutch that get used in FJ60s that came with the 4spd, or did the 3FE use something different? I'm searching around just in case the flywheel I have is too rusty to be resurfaced and used in the conversion. Be cool if I can source a lighter weight flywheel. Free up a little bit of power.
This is going off the assumption that the 3FE's flywheel used with the A440F will not work with an H55F conversion. Correct?
