floor tile question
Discussion in 'Chit-Chat' started by saint60, Aug 16, 2005.
  1. saint60
    saint60
    528
    Jun 16, 2004
    St Anthony, ID
    what is the advantage to using mortar rather than liquid nails when layinng ceramic floor tile. i can see if you had a wavy subfloor you can use the mortar to float the tiles, but if you have a level subfloor is it permissible to use liquid nails? i just got done using mortar to do the entry way to my house, but in hind sight it seems it would have been easier to use liquid nails. just wondering. :cheers:
  2. archie
    archie
    1,203
    4
    Dec 14, 2002
    NW side of chicago
    Liquid nails would leave more voids underneath the tile making it more suseptible to crack under heavy loads (moving fridge with dolly). Also any drop of a heavy tool would easily crack it. The motar, solidly and evenly applied , would dissipate those forces.
    I think the same amount fo liquid nails would probably cost more than motar. I would use liquid nails only if I was doing a small patch up job, but if you have to replace the tile again I think that liquid nails would be much harder to remove than motar (using chisel). Liquid nails is also harder to clean off of tools.
    Don't forget the underlayment.
  3. Herky
    Herky
    423
    Nov 1, 2003
    E. Washington
    What are you putting it on? Directly over a wood subfloor????
  4. saint60
    saint60
    528
    Jun 16, 2004
    St Anthony, ID
    no it's done. i used mortar. i was just curious as to why mortar was used. it's a pain. anyway-the even pressure thing makes sense.
  5. Jman
    Jman
    1,548
    176
    Feb 20, 2003
    If ya don't know, I ain't tellin'
    Ceramic tiles, and the grout between them, cannot tolerate deflection. Mortar provides a more stable base. With liquid nails, the adhesive will give under load and, eventually, the joints and tiles will crack.
  6. MoJ
    MoJ Moderator
    3,532
    427
    Oct 24, 2003
    Hopefully you didn't do that otherwise expect loose tiles in your future.
  7. Cookiemonster
    Cookiemonster
    564
    2
    Jan 19, 2005
    CA Bay Area
    Yup what they said above. The advantage of a good polymer based thinset is that it will also allow for better expansion and contraction without cracking grout lines & tiles.
    If ever placing tiles on an area with alot of movement or just to ensure crack free tile consider a crack isolation membrane system. Easy to put down and great insurance from future headaches.
    Lots of different manufacturers & all are very good.
    These three manufacturers are the most common & widely available on the market.
    http://www.mapei.com/MapeiAmericas/en/index.htm Available through Lowes, and most tile distributors
    http://www.laticrete.com/ Available through tile distributors.
    http://www.custombuildingproducts.com/welcome.aspx Available through Home Depot and tile distributors.
    I like Customs, but exclusively use Mapei because I've been through their factory training program. Love Mapei.
    Funny thing is I hate tile work. It's hard on the knees and back.
  8. wob
    wob
    2,813
    686
    Feb 28, 2003
    SC
    Man, that is an understatement. I will NEVER do tile work again.
