Flipping rear springs
Discussion in '40- & 55-Series Tech' started by cajunfj40, Mar 24, 2004.
  1. cajunfj40
    cajunfj40
    33
    Mar 19, 2004
    I saw in another post that flipping the rear springs gains four inches of wheelbase.
    Waht are the draw backs of this?
  2. woody
    woody unhelpful spotter Staff Member Admin
    10,726
    Media:
    317
    Albums:
    8
    2,326
    Jan 15, 2002
    Toquerville UT
    3.5"
    BAD: Increases any axle wrap problems you may have now, IMO, a wrap-bar is required even if still SUA. Can cause minor geometry issues with driveshaft vibrations. Will require minor brake line adjustments, relocating shock mounts. Odd are you get to trim your wheelwells out a fair amount, requires lengthening the rear driveshaft.
    GOOD: Provides added clearance at the tub for 35+ tires, longer wheelbase is better for hillclimbs, gives you a good excuse to find some 55/60 rear packs and swap them in.
    When I had rear leaves, mine were flipped, and I loved it. Only cost me 1 pinion when my 1st generation (and poorly design) wrap bar snapped...lol
  3. cajunfj40
    cajunfj40
    33
    Mar 19, 2004
    Would custom driveshaft eliminate vibration?
    Even if not it sounds good.
  4. woody
    10,726
    Media:
    317
    Albums:
    8
    2,326
    Jan 15, 2002
    Toquerville UT
    proper axle shimming will eliminate vibration....http://www.4xshaft.com has nice tech pics so it makes sense. In short, the down face angle of the t-case output must match the up face angle of the pinion input.
    No custom shaft required, just retube. Custom is no better than stock, unless you dump LOTS of money into some funky stuff.
  5. cajunfj40
    cajunfj40
    33
    Mar 19, 2004
    Thanks for the info. Sounds cheap. Greasy, but cheap.
  6. hammerhead
    hammerhead
    1,995
    2
    Jul 5, 2003
    Central, Utah
    Spring flipped a 40 the other day in less than 2 hours including body work. It really is that easy. Good mod too. Like Woody said you'll need a traction bar to control the wrap.
  7. HI^C
    HI^C
    1,234
    2
    May 22, 2003
    what is the word on redrilling military wrap leaf to keep it in the front?
    how much change in pinion angle if any?
  8. Herky
    Herky
    423
    Nov 1, 2003
    E. Washington
    Doesn't flipping the springs make the wheels sit more centerd in the wheel wells?
  9. big mike
    big mike
    52
    Dec 8, 2003
    I've been wondering the same thing as Hercdriver... my tires sit way forward in the wells. Don't want this when I install my BDS next month!
  10. Mace
    Mace rock scientist.. Staff Member s-Moderator
    21,369
    1,807
    Feb 17, 2002
    Las Vegas
    [quote author=HI^C link=board=1;threadid=13655;start=msg126758#msg126758 date=1080201319]
    [/quote]
    IMHO redrilling the military wrap to keep it on the spring mount instead of the shackle mount is absolutely necessary..
    It is not safe otherwise..
