CruisinGA said:If you are running a cruiser t-case, you do not need to remove the rear driveshaft. Check fluid levels, put everything in neutral, and unlock the hubs.
Excellent information. You speak from experience. I'm not sure about that 90MPH thing. Was alcohol involved?CruisinGA said:Get a solid tow bar, none of the foldup jobbies.
Smittybuilt sells a very solid one I have been using for 3 years.
If you have not corrected your caster with 4" of lift, you will need to with shims between the leafs and spring perches.
Magnetic lights are a good idea- I got a good set at Northern tool.
bungies on the steering wheel do not do a damn thing.
Mine has towed fine for me at all speeds up to 90 mph.
I've flat towed my 40 all over GA, NC, and TN. Never had a problem. I can cut neighborhood 90 degree corners without issue.
Cdaniel said:Be aware, unless you have modified your shift gate for the T-case, your front drive shaft becomes directly linked to the the rear driveshaft as soon as you move the lever out of 2H. T-case neutral only disconnects the T-case output shaft from the idler gear. If you run this way be sure the front drive shaft is up to the task.
It can be real ugly if it comes out at high speed.![]()
CruisinGA said:Magnetic lights are a good idea- I got a good set at Northern tool.
Capt. Jim said:Before I bought my trailer, I wired a trailer wiring harness into the brake/running lights on one of my buggies. Ran it up to the front bumper and just plugged it into my tow vehicle when I flat towed.
