Thanks for taking the time to have a look.
My FJ73 has an impressive flat spot on acceleration mostly noticeable in 1st, 2nd and 3rd gear. Its most noticeable when the engine is cold.
I took the vehicle to my mechanic today who advised that the accelerator pump seemed to be working fine, however he did adjust the spray which he mentioned was off. He also replaced the points and reset the timing.
When I picked it up tonight, the problem was still there (couldn't see the mechanic as it was picked up after hours).
The problem can be mostly overcome by pulling the choke right out again but thats a PITA and isn't going to help with my economy.
My Gregory's manual ( Aussie owners guide) lists the accelerator pump linkage and plunger as possible causes however I assume that my mechanic has covered this. It also lists a sticking check valve ball.
So before I dismantle the carby tomorrow ( and risk bits flying everywhere) does anyone have any other ideas or areas to look at?
Also, is it the small check ball at the end of the accelerator pump plunger or the LARGE check ball that I need to inspect?
I haven't played with a carby before so I would like to know if there are any real problems to look for.
I also replaced the spark plugs 2 weeks ago to see if that would help. NUP!
I have looked through the SEARCH function here and in the 60 section but nothing seems to cover anything other than a possible plunger fault.
Thanks for your time.
