Looking for a flat pitman arm for stock FJ80 steering box, do they exist? Are pitman arms interchangeable between Toyotas? As in something like this: Pitman Arm, Drop - Trail Gear
If you don't change your track bar location at the same time, prepare yourself for bump steer. I have a simple calculator that, based on the lengths and relative heights of the track and drag link, you can see what sort of bump/droop will start inducing unpleasant bump steer.Looking for a flat pitman arm for stock FJ80 steering box, do they exist? Are pitman arms interchangeable between Toyotas? As in something like this: Pitman Arm, Drop - Trail Gear
At the rate @richardlillard1 is going, he may not have a panhard tower much longerWith the stock sector, the spline count, size, is the same as other Toyotas, so interchange. The '80 pitman is curved to clear the panhard tower, have never seen an aftermarket curved pitman?
Maybe you should take some time and teach him how to driveNot all of that, he has only broken that part twice, has broken other stuff more often!
Its sensitive. Youre changing lengths and relative heights. And bump steer sucks. Id model it. Text me your email addy and I will email you the spreadsheetWhat are the variables that would affect bump steer on my current setup?
What I'm trying to do is change the steering setup a bit to ditch the weird y-link/inverted T setup
My idea is to have the draglink go directly to the top of the Hellfire arm on the outer hole.
That would interfere with the frame on the passenger side so I was planning on notching the frame and lessen the angle of interference by having a flat pitman arm that essentially raises the draglink.
So - would raising the draglink at the box and the knuckle without moving the panhard introduce bump steer?
Best photo I have at the moment. Draglink would go to top of Hellfire arm via a heim joint on a single bolt.
