Flashing ck eng light (1 Viewer)
kling-on
Kool Arrow
Pimpin part in SanAntonio TX
Website
www.texas4x4.org
Well on the way home my ck eng light started flashing ... Then I started loosing power made it the house before it died... I think it's the fuel pump any ideas, I'll ck the codes tomarrow
I love my 5.3 most of the time but this s***s drivin me crazy
I can't say how the pump reacts on a 5.3 but when the pump dies on a 62 it's just dead no slow make it home.
I have heard of similar symptoms turning out to be the the alternator dying. I had some flickering dash lights shortly before the alternator died in my diesel. The best part of the diesel is that I drove around all day with a dead alternator, motor didn't care.
Tony
On newer OBD2 engines a flashing check engine light means a missfire that could damage the converters. Pull codes and see whats going on. Insufficient fuel due to a failing pump could cause this. There will be lean codes and missfire codes if it is a fuel supply problem.
started right up this mornin drove to work cked the codes and no miss fire code .... had some tranny codes :mad: cleared them hopin they were from runnin it with the tranny un pluged after swap :rolleyes: no problem to or from work:bang: I got a spare fuel pump and filter just in case...:steer:
shouldnt be the alt just replaced that cause the last installer broke the insulator:rolleyes:
no converters to damage ... but also no codes
