I've been getting this loud higher pitched tick under acceleration, sounds much like valves clapping. However, I knew it wasn't valve sounds when I pulled the number 6 piston's spark and the sounds immediately dissipated.
So i pulled the oil pan today, and found it to be sparkling from many shreds of some material. Number 6 rod bearing, cylinder walls, and wrist pin all felt and looked fine.
The flakes appear to each only have one worn side to them, and they are quite thin, a bit thicker than aluminum foil.
Any ideas on what to check?
