FJZ80 Valve Rattle
Discussion in '80-Series Tech' started by Cruzer_89, Mar 2, 2007.
  1. Cruzer_89
    Cruzer_89
    895
    42
    Apr 23, 2004
    Central Florida
    How difficulty is it to do a valve adjustment on my 96 FZJ. I get a little rattle at low RPM's. I've gotta replace the valve cover gasket so i figure i should take care of that. The 80 has 183K on the Odometer it has a couple of leaks but other than that runs great. I'm sure she is probably overdo for an adjusment.
    Does the haynes manual have good instrctions on how to do it? Should i take it to my mechanic?
  2. nodaksn3
    nodaksn3
    744
    Albums:
    2
    30
    Jun 15, 2006
    Ipswich, MA, North Dakota, Phoenix
    EZ to do yourself, I think you can probably do a search here, or get a Haynes manual. Although I haven't done it to me '80, I did adjust the valves on my several '40's, '60 and '62 with no problems. Just don't get them too tight.
  3. Cruzer_89
    Cruzer_89
    895
    42
    Apr 23, 2004
    Central Florida
    Valve rattle
    The FZJ80 4.5 motor is different from the 4.2 and the 4.0. It has shims under the cams, there is no set screw to adjust.
  4. Rookie2
    Rookie2
    3,026
    80
    Dec 15, 2003
    Knoxville
    I also get a little "chatter", I think these engines are just inherently a little noisy that way.
    If you're going to do work like this, you should buy the FSM. I just replaced my valve cover gasket and checked my clearances this last weekend. Not to tough a job, except replacing the spark plug tube seals is a little bit of a pain. To actually change out the valve shims (if you have some that are out of spec.) requires a couple of special service tools that will run you about $100.
    :beer:
    Rookie2
  5. Cruzer_89
    Cruzer_89
    895
    42
    Apr 23, 2004
    Central Florida
    Valve Rattle
    So your saying your chatters a little with less than 100K on it. So mine should be good then too...
  6. Rookie2
    Rookie2
    3,026
    80
    Dec 15, 2003
    Knoxville
    Yes. I expected to find some clearances out of the specified range, but I was kind of suprised. For the most part, my clearances were right in the middle of the range, with a few right at the top end of the range. I'm not 100% sure what the source of the chatter is, but from other comments it seems to be pretty common for these motors. I've been meaning to get the stethescope out and do some listening.. maybe this weekend.
  7. DTAYLOR
    DTAYLOR
    1,029
    3
    Feb 20, 2006
    Texas
    Check out the idler pulley, just left of the alternator. Remove it to rule it out. The belts will tighten fine without it. I actually ran mine about 20k without one.
  8. Rookie2
    Rookie2
    3,026
    80
    Dec 15, 2003
    Knoxville
    Good idea. I do tend to think it's from the front end somewhere, and I think I've put a stethescope in the engine before without hearing anything like tapping. I've got a new AC idler, and OEM belts, so the AC idler would be a good place check, and it don't cost nothing.
    :beer:
    Rookie2
