FJZ 80 stock Min ground clearance, approach/departure angles
Discussion in '80-Series Tech' started by 94landcruiser, Aug 20, 2006.
  1. 94landcruiser
    94landcruiser
    1,067
    3
    Mar 6, 2006
    Westwood, Ca/Ixtapa MX/Ahwatukee, Az
    I was reading a comparison of the new Explorer and Commander and the artical states the offroad capabilities and gives the tc type, diff types and dimensions.
    I searched here, the net, the FSM and nowhere did I find this info.
    I asked on 3FE (and in two days got no response, seems they are a bit of a clique and only answer each other) I measured my truck but am not sure I measured correctly.
    Anyone know or know where I might find this data?
    Thanks
  2. txtortoise
    txtortoise SILVER Star
    378
    Media:
    1
    Albums:
    1
    86
    May 7, 2004
    San Antonio, Tx
    Someone with the 1994 brochure may be your best bet. Not much on Google. Probably not dramatically different than this:
    2006 = Angle of approach/departure/breakover (degrees) 31/24/24
    http://www.toyota.com/landcruiser/specs.html Dimensions
  3. 94landcruiser
    94landcruiser
    1,067
    3
    Mar 6, 2006
    Thanks. I googled, searched here and on other boards but did not think to look at Toyota and was not sent there by google.
    Anyone have a stock 100 and 80 that can see the differances?
    I looked at the new 80's here:
    http://www.toyota.com.ve/showroom/vx_autana/specs.html
    But these specs are not there. :(
  4. FJ809496TLC
    FJ809496TLC 80 series addict GOLD Star
    1,965
    51
    Jul 30, 2003
    Texas, Pinas and Germany
    Angle of approach is 34 degrees, angle of departure is 22 degrees and the minimum ground clearance is 10.8 inches. These infos were found in the original brochure.
  5. 94landcruiser
    94landcruiser
    1,067
    3
    Mar 6, 2006
    Great! Thanks very much!
