FJ80 TRE Saginaw Arm
Discussion in '40- & 55-Series Tech' started by ranger, Feb 23, 2007.
  1. ranger
    ranger
    1,160
    6
    Jan 18, 2003
    Mountain Hole, Idaho
    Anyone have a source for a reamer for a fj80 tre, or a place to get a saginaw steering arm with the correct 80 tre taper?
  2. John Smith
    John Smith In the garage
    4,201
    Media:
    6
    Albums:
    2
    257
    Jun 7, 2004
    Maryland
    You should be able to buy a reamer from the Snap-on truck last time I checked and I believe Marksoffroad.net sells arms already reamed as do probably other vendors.
  3. ranger
    ranger
    1,160
    6
    Jan 18, 2003
    I searched and can't find much about it or any venders selling the saginaw arms with the 80 tre taper........Marks site must be down, no workie.
  4. Medusa
    Medusa
    416
    1
    Jun 17, 2002
    Why not just use a GM 1 ton TRE. It has only a slightly larger shank (relative to the 80 series TRE) and will fit the Pitman arm without reaming.
  5. ranger
    ranger
    1,160
    6
    Jan 18, 2003
    Yep I could do that if it comes down to it , but then I would have a 1 ton tre on one end of the relay rod and an 80 on the other, since the steering arm already has a 80 taper. Not a big deal really but its nice to have everything the same, less parts to carry.
