fj75 rebuild kits? and questions
Victoria, Australia
Good morning ladies and gents.
I'm trying to plan and budget for following:
rebuild swivel hubs + wheel bearings kit
Brake rotors + pads (haven't checked rear)
Clutch kit + rear main. (Exedy sport hd kit)
Suspension. (terrain tamer parabolic full kit)
I've noticed some ebay swivel hub kits with the same brand bearings ect can be a couple hundred dollars cheaper than well known sellers Is it worth paying extra?
Bearing hubs... should I be replacing with bearings?
I have some 33"s -22 off my old patrol all under 2 yrs old and only a handful of ks I've heard they might rub front and rear can anyone confirm or deny? If so what offset would it need for no rub? I will be using it off road 👍
What else should I be looking at?
I'm wanting to knock it all over in one hit. I'll be getting a shop to do clutch and seals as troopy wont fit in garage so I'll be playing in the dirt lol
I know this is pretty vague but i appreciate the input and support cheers
Don’t know best source for knuckle kits in AUS, but ask around
Repack your front wheel bearings first. Inspect them for wear otherwise reuse.
Don’t replace hub unless burnt or the seal surface is fried and you cannot speedy sleeve it.
If your rotors are within spec and not warped you can just reuse them.
go easy on spending. Formulate a plan first. Drive the truck. You will have more questions in six months.
Hey rick_d thanks for replying.
the front packs are sliding over themselves grinding and crunching and the shock bushings are toast I've tried tightening the packs with no change. Any thoughts on how i could shut them up for a while?
If you have the wheels try a fit, no guessing then
All good I'll be taking troopy and kids camping on weekend and won't have a chance to check clearance out until then... Don't want to end up stuck or broken with kids.
Will have to fit them up another time 👍
