Hello
The boss has a12/88 fj 62 with just over 200K and its got a great problem with flooding out
It happens only when hot and it will be running fine then lose throttle response and bog down then just stall out . You can smell the raw gas when cranking. I discoed the cold injector thinking it was the problem but still did the same just cranked and cranked . It has good spark . I found that if I discoed the fuel pump relay under the right kick panel I can get it to start and run on the fuel in the rail then it will die . if I plug the relay back in it will try to flood out and I have to keep plugging it in and out so it will still run till the point where it clears up then runs fine . I know someone can point me to the light as this is one big PITA
Thanks ahead of time
