I have been battling the little green window control box for to long Is there a work around from this green devil in my door????
Do you offer a service to refurb the master window/lock switch? I brought it to a guy who cleaned up all my contacts a couple months ago, but now my power lock switch has stopped working again, and my 3 auxillary window switches only work intermittently from the master. Each window works fine when pressing their own respective switchesWhat is your window doing (or not doing?).
I offer a refurb service but whether it would help you depends on your symptoms.
For those I don't, since good quality replacements can still be sourced new (for less than $100). Once significant wear happens to the contacts inside, cleanup only buys you at best a couple years of service, and on average a few months. I had experimented with it earlier last year and there were just no satisfactory results.Do you offer a service to refurb the master window/lock switch? I brought it to a guy who cleaned up all my contacts a couple months ago, but now my power lock switch has stopped working again, and my 3 auxillary window switches only work intermittently from the master. Each window works fine when pressing their own respective switches
I can only find brown ones - have you sourced a grey one?For those I don't, since good quality replacements can still be sourced new (for less than $100), and once significant wear happens to the contacts inside, cleanup only buys you at best a couple years of service, and on average a few months. I had experimented with it earlier last year and there were just no satisfactory results.
I tried the cheap knock-off version, and haven't had a problem in two years. I was also having trouble with passenger side front. New switch there solved problems that I thought were motor related. Nope...just switch. FWIWDo you offer a service to refurb the master window/lock switch? I brought it to a guy who cleaned up all my contacts a couple months ago, but now my power lock switch has stopped working again, and my 3 auxillary window switches only work intermittently from the master. Each window works fine when pressing their own respective switches
I'd buy the switchdoctor option, but they only offer it in brown. I have a grey interior and would like it to match... Perhaps paint?I tried the cheap knock-off version, and haven't had a problem in two years. I was also having trouble with passenger side front. New switch there solved problems that I thought were motor related. Nope...just switch. FWIW
One thing you can do is swap the internals of the new Switchdoctor unit into the gray trim of the OEM unit. I did that with mine and it went together beautifully.I'd buy the switchdoctor option, but they only offer it in brown. I have a grey interior and would like it to match... Perhaps paint?
aah trueOne thing you can do is swap the internals of the new Switchdoctor unit into the gray trim of the OEM unit. I did that with mine and it went together beautifully.
Great idea!One thing you can do is swap the internals of the new Switchdoctor unit into the gray trim of the OEM unit. I did that with mine and it went together beautifully.
