FJ62 transmission oil cooler installation help needed (1 Viewer)
New York
sorry to bother every one again as I am running into more problems
I got a new radiator from criserparts.com and the kit comes ( has to be) with the external auxiliary transmission cooler because the OEM spec one for automatic is no longer being produced. . it is a beefy one with the cooling fan I think it is made by sppeedmaster79.
I DID see many posts here about the oil cooler mounting but never seen any post about this big boy ever installed on a FJ62.
my truck is sitting at the shop awaiting for the solution...
help me please
That is a big boy. Brackets are going to have to be fabbed for it, then mount it where it will fit.
Not very helpful advice I admit- but that’s the gist of it.
You’ll want the oil to flow from bottom to top.
The in-tank cooler on the radiator removes a tremendous amount of heat before it gets to the auxiliary cooler. You will definitely need that cooler in order to keep everything cool enough without the radiator cooler. I hope the fan is thermostatic, as you don't want to overcool the transmission.
My question here is where and how to install this big boy?
