FJ62 trans and engine.
AZLC
Peoria, AZ
I recently purchased my first LC, a '88 FJ62 with 101K???. After driving it for a week or so I noticed a couple things.
1. 2-3 shift revs, more noticable when cold
2. Tapping sound from engine.
I do not remember either of these at time of sell. I broke the cardinal rule of not doing a compression check prior to purchase. Thanks to the threads in this forum I have started the following.
For the trans I am going with reptitive changes of ATF, starting with a mechanic draining pan and replacing filter. Completely black fluid spew from the pan splattering the mechanic. I got the feeling he did not want to see this truck again. So far, 21qts of ATF have been exchanged. Still slips between 2-3 every so often.
After reading the threads in this forum I got the idea this engine had overheated at some point. So I did a compression test.
Compress test results:
cyl 1 155
cyl 2 149
cyl 3 146
cyl 4 149
cyl 5 134 ouch!
cyl 6 156
The truck starts and runs ok. Does anyone know how much power I am down?
esh
Oregon
No idea about what kind of power you're down, but I thought it interesting your compression numbers are in a similar pattern to mine-
#1 - 165
#2 - 155
#3 - 160
#4 - 160
#5 - 145
#6 - 165
what's up with #5??
btw, 200k with nothing touched, regular maintenance but it's been hot a couple times since I've owned it.
What's up with #5? See Woody's post in Tonkota's thread about plug fouling in #5 cylinder. Sounds relevant to me.
Tapage
Club 4X4 Panamá
Panamá
cyl 1 155
cyl 2 149
cyl 3 146
cyl 4 149
cyl 5 134 ouch!
cyl 6 156
Is Not to bad compresion number .. remember is a Toyota Engine .. it can do .. !
Your compression is within normal limits, or at least very nearly. Your lowest number should be within 10 per cent of the average...just barely misses it. Shouldn't be your problem. the ticking noise is probably the valves needing adjustment. If you're planning on going back to the po for relief, run a carfax to verify the mileage. If your mechanic told you he "replaced" the filter, bend over and grab your ankles....62's have a cleanable metal screen. I'd adjust the valves, and I think you're on a good track with your tranny maintenance...but I'd do it myself. Couldn't be simpler, really.
