I've taken the ancient stock leaf springs out and I'm installing a set of used Tuff Country (discontinued) 3 inch springs all around. I'm currently on the front axle. I'm doing one side at a time, not sure if this is a great way to do it.
This is where I'm having trouble - I attach (in this order) the pin, shackle, and now I'm on to the perch/u bolts. I tightened them down a bit, then noticed the centre bolt on the leaf spring doesn't align with the spring perch hole for it. My shackle is pointing backwards, which I know isn't right either. If I disconnect my shackle, then try the U bolts, should everything align?
Thanks, this site has really been a great help
