FJ62 rear wheel won't turn (1 Viewer)
Austin, TX
I'm having a problem with my 1988 FJ62 where the rear driver's side wheel is locked up. Got the vehicle on blocks and all other wheels turn freely. Brakes appear to be working OK on all other wheels. Is this a bent/damaged axle, differential issue, or a brake problem? Any advice would be appreciated!
Vancouver, Canada
Maybe the parking brake seized. Try to take the drum off, and don't forget to remove the big screw through the drum otherwise it won't budge
3_puppies
Helena MT
gonna be hard to get the drum off if the brake is tight
I was thinking it may be the bellcrank for the ebrake, it is on the back side of the drum and the cable attaches to it
Vancouver, Canada
Those bell cranks are always seizing up. On 4runners and 80's it's because they used aluminum and steel and there is galvanic corrosion. Not sure if it's the same with 60's.
Zjohnsonua
Huntsville, Alabama
I'm gonna be fighting this soon on the new project. 60/62s bell cranks just rust up. It's all ferrous. PB blaster, wire wheels, time, and hammers are all going to be needed to break them loose and get them back to functional.
Make this a rear brakes project and go through both sides. You'll feel better about the system as a whole thereafter.
OSS
Oblivion
Once everything is released (bellcranks and adjusters) use two long M8x1.25 bolts in the threaded holes in the drum to screw/press it off. That's what they're for.
Southern Colorado
My 62's rear drum brakes (one side) were so impossible to get apart that I cut the brake nails on the back side of the backing plate, and pulled off the drum with the shoes - it all fell out on the ground as I went, so to speak. There is more than one way to skin a cat.....
I later found cheap brake nails and a hardware kit at Rock Auto and put it all back together, using the other side as a reference.
San Francisco
I had a similar problem with my FJ62 passenger rear not turning. I used Kroil on the ebrake mechanism. I put in 4wd and dragged it back and forth 10’. It eventually broke free. It works
