FJ62 Parts on 6/77 FJ40?
Discussion in '40- & 55-Series Tech' started by 77TLCFJ40, Jul 29, 2005.
  1. 77TLCFJ40
    77TLCFJ40
    5,754
    867
    Jul 30, 2003
    Madison, MS
    FJ62 Brake Booster and Master on 6/77 FJ40?
    I recently found a FJ62 in a wrecking yard and I'm trying to decide if buying it and parting whats left is worth it. Part of what may make this attractive is compatability of the 62's parts with my 6/77 40. Sell most - use some is the idea. So if I break even, its OK with me.
    Questions in order of importance:
    1) Will the FJ62 brake booster and master work on my 6/77 FJ40?
    2) Any different answers/changes if I upgrade to rear disks in the future?
    3) Will the Throttle cable work on a 40 with little modification? Planning OBA
    4) Is the 62 starter "gear reduction" and will it work on my 40?
    5) Will the alternator swap?
    6) Coil swap?
    7) Anything else I should consider?
    The 62 3FE engine is gone, but the auto tranny is still there. The truck was hit in the front passengers corner which pushed the axle back and broke the transfer case in half. Front and rear axles are available (with 411 difs). Few good body parts: hood, DS front fender, upper & lower tailgates, back passengers door. Most dash parts and grab bars are still present but the rest of the interior is gone. Lots of small parts on the inner fenders under the hood. The PS and Smog pumps are frozen. PS gear and hoses are available. The 62 is white with blue/gray interior.
    Thanks for the advice!
  2. Texican
    Texican s-Moderator
    5,964
    Media:
    175
    Albums:
    7
    321
    Dec 17, 2002
    Bonham Tx.
    If you get the truck, PM me I need some small items and there is a guy in LSLC Dallas that was needing a trans......no way to know condition of that one though......
  3. Landpimp
    Landpimp
    16,093
    Media:
    1
    2,078
    Mar 14, 2003
    Gig Harbor WA
    booster should work, might have to flip it upside down. Master, maybe
    t-cable, prolly not
    yes starter is GR and will swap
    alt, prolly not
    coil and dizzy, nope.....well maybe the coil, betting not though
  4. 77TLCFJ40
    77TLCFJ40
    5,754
    867
    Jul 30, 2003
    Madison, MS
    Can anyone tell me why the brake booster and master would not work? The FJ62 master bore size is 7/8". What is a 6/77 FJ40? Any big difference in the booster shaft length between a 62 and 40? Thanks
