- Location
- United States
All SOLD.... Thanks everyone...
How much did this go for pls?Old Man Emu lift SOLD
please let me know if that fall through. thxOld Man Emu lift SOLD
Thx. Good to know$480 for all of it...
62 power steering lines available? If so, how much shipped to 78070. Thanks. Jimmy
I saw it listed under the fj62 list for $15. Unless it's sold.
Thank you.
Looking for the rear seat belt covers for both sidesLeftover FJ62 Landcruiser parts (1988-1990) from several part outs over the years. This is all I have, nothing more. There are also a few FJ60 parts and as you know, some stuff is interchangeable between the 2 models..
Located in NW Tucson (Oro Valley)
Most of the photos: https://www.irista.com/gallery/ujoze6gr6wf9
FJ62 3FE ENGINE STUF**
-DENSO spark plug wire set brand new in the box $20
-Front exhaust manifold section in great shape $30
-3fe rocker arm cover/valve cover $20 used original oem
-87-92 3fe distributor with rotor/cap/wires $150 (cap/wires/rotor are new Denso and Bosch)
-Engine bay blower works good $65
-Smog pump with some extras $50
-Charcoal cannister $75
-Maf sensor/airflow meter/air filter housing setup $170 for all of it
-OEM toyota starter $80
-Power Steering pump with reservoir and mount $160 for all of it
-Fan shroud, good shape $30
-Fan for radiator $40
-Set of OEM horns $25
-Fan clutch $40
-Thermostat housing with most sensors on it $90
-Good working AC compressor $120
-Belt pulley, etc., assorted mounts (take the whole pile) $50
**FJ62 BODY TRIM ELECTRICAL ETC
-Speedometer, tach, fuel/temp gauges $75 each
-Front bumper hook and mount $30
-Gray metal glovebox door with ding $15
-Glove box cardboard shell with light $20
-Unknown brand trailer hitch, heavy duty frame mount $95
SOLD -Old Man Emu front and rear springs with front OME greasable shackle mounts. Front 2.5 lift 6 leaves, rear 3.5 lift 8 leaves. Surface rust from sitting in a field, VERY GOOD arch, were not utilized long before the engine gave out.
Also included the front OME steering stabilizer and 2 front OME shocks. $480 for all of it.
-Sheepskin/wool seat covers in dark gray/black. Used in good shape, were on FJ62 seats $120 for the set.
-Used carpet set....front, middle, cargo (no tailgate) in brown and decent condition $160 for all
-Ashtray, $15
-4 brown headrests, $25 each
-Bumpers, 3 front ones (oem chrome) with dings, dents, etc. Bumper with the endcaps $140, other 2 without $85 each.
-Bumpers, 2 rear ones, oem chrome without endcaps $90 and aftermarket black with endcaps $140
-Front bumper set of endcaps, left and right, decent shape $50 for the set
-Rear bumper 2 sets of endcaps, left and right $50 per set
-1 driver and 2 passenger sun visors, good shape $30 each
-Steering wheel center piece, brown $20
-Cargo area wheel hump cover in brown for the late 89 to 90 FJ62 (no ears) $30 for the set
-Brand new, in the box OEM Toyota chrome rear license plate light $220
-Used rear license plate light, good shape $160
-Used rear license plate light, good shape with some dings $90
-Rear seat, bottom section in brown.. Nice fabric but NOT the oem pattern $45
-Rear seat belts (2 rollers, 1 male, and the 3 females) all in brown off a 1988 FJ62 $120 for the set (no shoulder)
-Driver and Passenger brown pillar trim for over the shoulder belts, fair $20 for pair
-2 cargo area white pillar trim near the hatch, good shape $20 for the pair
-4 brown headrests good shape $30 each
-Set of front seatbelt receivers in brown, fair shape $30 for the pair
-Front foot area kick panels in blue/gray, both sides in good shape $35 for both
-Automatic shifter plastic trim/surround gray/blue (one of the screw holes has been broke slightly, look at pic) $10
-Rear heater with the hard lines, etc. going to the engine bay $120 for all of it
-Rear hatch window fluid bag with pump motor $25
-Blower fan with housing located under the dash near the passenger side $35
-Front windshield wiper motor works great $90
-Rear liftgate window wiper motor works great $90
-Hood support rod $20
-Set of 2 Aisin locking hubs with all the bolts/nuts $140 for the set
-Center hood latch as shown in pics $20
-Emergency brake lever/handle black $35
-Emergency brake lever/handle brown $35
-2 Rear bumper center mount piece (bolts the center section of the rear bumper to the frame) $30
-Trans to crossmember mount $25
-2 rear frame stubs with body mount, both driver and passenger side $40
-2 front OEM skidplates, $25 each
-1 auto trans skid plate $30
-Front drive shaft $90
-Rear drive shaft $100
-Hood prop rod $20
-Rear seat bottom hinges (bolts onto the floor) $30 for the set
FJ60 Stuff (1981-1987)
-Rear steel bumper painted black, aftermarket. Straight, no bends or dents and comes with endcaps $140
-Rear chrome OEM bumper with dings, etc. $90
-Used rear license plate light, good shape $155
-Used rear license plate light, good shape with some dings $95
-Rear seat lap belt retractor left and right in brown $75 for the pair good shape, retract well
-FJ60 passenger seat back section in brown $35
-Speedometer cable, nice shape $25
-FJ60 rear seat bottom in brown $40
-FJ60 positive battery cable from starter to battery $20
-FJ60 windshield wiper motor works great $90
-FJ60 rear liftgate window wiper motor works great $90
