I just finished a coolant rebuild on a 62 I bought from a guy who abandoned it after he blew the water pump while he was on a road trip (I wasn't able to test drive truck). I replaced pump, clutch, fan, radiator and replaced both power steering lines while i was in there. I also had the alternator rebuilt while the easy access was there. I also replaced all the sensors and switches in the thermostat housing.
My question is the truck fires up and idles beautifully (650-700 rpm) but once I take it out on road I have NO power. Acceleration is non existent. I tried 2 quick test drives of about 1 mile then got back in garage to look around for vacuum leaks etc. I then tried again - this time letting engine warm up and get to operating temperature. This time I had much better/more normal acceleration - although I did have some slight sputtering.
Since the truck seems to operate more normally once engine is warmed up could it be one of those sensors in thermostat housing? Or something else?
I did try the "paper clip" trick on diagnostic test and I got no errors (continuously blinking engine light)
