About to start gathering parts to convert my fj62 to manual. Going with an h41 four speed and fj60 3.73 gears.
Got some questions..
Is anyone running this combo?
Any tips before I start on this?
Also, how difficult is it to swap 3rd members?
I've read many threads on swapping manual transmissions into 62's so I'm somewhat familiar with the process and most everything that is needed.
But I want to make certain I get the right h41. I know there are long and short versions, and different output/input shafts. Since I'm going to be using my 62's split case and have the stock 3fe, I would want a h41 (with the spacer if possible) with an f/h input shaft and a course 19 spline output shaft? Is that right?
What other variations did the h41 come in that I could use? Did the earlier ones have a 16 spline output shaft? If i could not find a later one, would one of these still work with my transfer case? I don't have to have the one with the spacer, but it would probably be better.
Thanks for the help.
