New owner here of an '89 FJ62 (new to Land Cruisers, in general) with loose-on-center steering. Any easy/quick fix to this problem on these vehicles? If not, what's the best approach? Many questions to come, I'm sure. Thanks. Rich
It could be a number of things. Factory spec for "play" in steering wheel is 1.5". But, that can mask play in a bunch of other areas. You can have wear (and thus play) in the steering shaft, drag links, tie-rod ends, wheel bearings, shocks, spring bushings, steering box, ummm, that's probably it.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
