FJ62 high idle = timing issue?
I apologize if this is one of those questions that makes everyone groan - I am new here, have owned 2 FJ62s but now mostly work on late 80s BMWs, which I am prettty well versed on mechanically - unfortunately I never worked much on my FJs (didn't need it) so I am pretty much a nimrod here. We still have an 89 FJ62 in the family (but it is currently far from where I live so I can't get my hands on it) that ildes at 1400 rpm or so, albeit smoothly. Seems to run fine otherwise. About 100k miles. My parents had it in for a radiator swap and mechanic said that timing is advanced to 22 and when he set it back to 7 it "wouldn't run". So he says that it needs "timing work" that'll run $1500 or so. I am trying to talk to this guy myself but wanted to get any informed input as to what might be going on here. Any help appreciated.
I doubt it is the FPR. Timing sounds about correct if it was advanced a bit in the past. It may be that the dist was pulled and not reinstalled correctly. Run the codes. First thing to do is unhook the throttle cable and see what that does, might just be bound up a bit. I would look for a VAC leak also. Not sure what "timing work" means but $1500 sounds high. COuld also be the AC idle up is wacky, throttle body plate is bound up, computer is acting crazy, etc.... Ask him just how did he determine you were at 22' of advance? The computer advances the dist on its own so it may be sending a bad signal. Most of the time there is no silver bullet with the 62. Just keep plugging away with the OEM manual and it will get fixed eventually.
talked to mechanic...
He said you have to put a jumper in there to check timing, and that he found it to be WAY advanced, at least 22. Back at 7, it idles fine at 650 but stalls/has no power upon take off. He believes that chain is stretched/worn and so are cogs, or I wonder if it's possible to jump a tooth in these? Anyway, he wants to replace the chain and cogs, 12hrs labor. Thing is it runs fine other than high idle, so I am not sure this needs to be done sooner rather than later. If I can get my hands on the car (probably not any time soon) I would like to clean the TB etc. BTW, I know it's not a cable issue, there is actually some slack in the cables. Thanks for any additional comments.
I think he's lying to you, or he has not even looked in a manual for the cruiser. It amazes me that more people dont file complaints with the BBB. He is willing to charge you for 12hrs of labor, but not willing to look in a manual for 5 minutes to determine that it might not have a timing chain. Timing Gears, there is no chain.
I would call him up, tell him to write up a work order and estimate for replacing the "timing chain", and then ask what he will bill you when he finds there is no chain. Fawking POS mechanics suck. Happy to make $1500 off of unsuspecting customers.
Sorry for the rant, just dont like mechanics at all, after reading some of the repair estimates for the folks that I bought my FJ62 from.
-Brett
Wow - thanks for the info - so then I assume in place of a chain or belt it uses gears? Sorry for the ignorant questions, I am ordering service manuals but don't have em yet. So then the question remains - if timing was in fact way advanced by some previous mechanic, and it runs fine but idles high, but it won't run at normal timing setting, is there anything to point to here or are there too many possible causes. One of our problems is the car is on Nantucket Island and there are few mechanics and I can't get to it. Mechanics are also of course very expensive. Front rotors were warped, so he replaced rotors, put new bendix calipers in w/ pads, repacked bearings etc, and replaced leaking master cylinder - cost about $1200!
No ignorant questions. Thats why people answer questions, so others can benefit. Glad you or your family did not get taken on this deal...
good luck,
I'm with 'dd113' on this one.
First thing I would do is check the dizzy for correct number one spark. I'd bet on a hunch that somebody pulled the dizzy and dropped it back in 180 degrees off. Seen it happen one to many times for my tastes.
HTH,
Cahil
The more I think about this.....
The computer decides how much adv you get. If you are idling high it will advance the timing to match the vac load. Get the idle down then the timing should fall back to normal but you want to run it way aedvanced just to get some more power out of it.
I bet David is right, the idle is the problem, not the timing. Something is idling the truck up, which is advancing the timing.
FYI, unless I run premium gas I have problems with Pinging when my timing is advanced.
:flipoff2: replacing that stupid thing is has now cost me $300+.................. for a $90 part
Kaderabek said:
I'd replace the fuel pressure regulator first.
TJK
More good info, thanks guys. I wish I could get my hands on it! I will eventually, so what would be first plan of action? I will check for any potential air leak sources, and make sure cables aren't binding (I am pretty certian they are slack). But then I think it would make sense to clean the tbody. Do these cars have an idle control valve (essentailly a computer-controlled air bypass valve that allows air to bypass the butterfly, thereby opening the AFM flap and increasing idle)? In BMWs they can get gunked up or fail and cause idle problems. Also, has anyone ever seen a problem with the AFM flap sticking (also happens on BMWS)?
Excellent plan. Yes, there is an AFM, but whatever you do don't dismantle the AFM sensor thingie - it will break internally (as parts breaker LandPimp found out somehow :) ). I would replace the ignition parts (plugs, wires, cap, rotor), spend some serious time looking for vacuum leaks (spray some carb cleaner around with the engine idling - it will speed up if it sucks in any carb cleaner through a leak), adjust the TPS, and do the checks for the AFM and other things (this is all in the FSM, see below). Definitely spend some time cleaning out the throttle body.
The very last thing you should do if everything else is ok and it still idles fast is turn the golden screw on top of the intake plenum. It is basically a controlled vacuum leak and will let you adjust the idle speed.
You need to get a Factory Service Manual. About $70 and a MUCH better investment than the $1500 the idiot quoted you. You can get one from any dealer, or from Toyota Publications, 1-800-622-2033, $67.65 + shipping.
You should also join the 3FE mailing list - it's the BEST collection of knowledgeable 3FE owners anywhere: http://autos.groups.yahoo.com/group/3FE/
Cool - sounds like a plan. Will join the group also. Didn't realize there was an idle speed screw - have one on my M5 so I know that it is the last thing you check/adjust, not the first! FSM will be my next purchase...
There is an Idle Control Solinoid just down from the TPS towards the ft of the fuel rail but mounted on the intake. WHen you shut the truck off you should hear a bunch of little clicks from it. You will need to have your head near it to hear it. No clicks=bad. Remove the harness and the 3 screws that hold it in. Dont take it apart just clean the plunger and the hole it goes into. Regulates the amount of air that flows and, controls the idle.
On my rig I had a high idol that was solved by adjusting the throttle position sensor with an ohm meter following the FSM also if there is pressure in the gas tank u could have a vaccum leak at the charcoal canister check valve or any of the dozens of other stupid vaccum hoses
