Here is a good one.
My headlights are out. High beams work but no low beams. They both went out at the same time which is unusual. Something is up.
Back story:
The muffler on my FJ62 developed a hole. It is currently being replaced but during the time I was running the truck for a couple of months with the muffler hole.. the sucker rattled and vibrated underneath like you read about.
The radio went blank due to the interference caused when I accelerated in the truck. If I turned the defrost on full blast it canceled out the interference and the radio worked normally.
I noticed lately that the voltage reading on the dash for the battery was up to as high as it can go. Very odd.
Now my headlights (low beams) are out and the voltage reading for the battery on the dash is back to normal.
Anyone have a clue? Did I vibrate something loose? Or did I cause some sort of electrical interference? The voltage reading scenario is weird.
I haven't had the chance to look at it yet as it is in the shop for the muffler replacement. I figured I should do that first.
thanks
Back story:
thanks
