FJ62 fuel pump issues (1 Viewer)
I replaced my fuel pump a couple years ago. Rig has been driven very little. Anyway, went to start it and it wouldn’t start. Went through some diagnostics and got to the paper clip Fp to +B jumper in the diagnostic port. Couldn’t hear the fuel pump. Went to pull the paperclip and the dang thing was hot! I couldn’t find this scenario described anywhere. I’m guessing fuel pump is locked up? Any guidance would be welcomed. Thanks!
3_puppies
Helena MT
check the connection in the left rear quarter panel, below the jack and tool roll.
other option is to remove the rear carpet and run a hot wire and ground to the connection by the fuel level sender and see if it works.
ToyotaMatt
Factory Focus-Point Mind-Set Approach
Supporting Vendor
GOLD Star
EAST COAST
Did you replace both your Inline black canister fuel filter , and and more important the mesh screen on the bottom of the picki up tubes when you installed the new pump ?
was your new pump a OEM toyota NipponDenso Unit
or
a ROCK AUTO .........................type ?
sitting for a long time can clog older in place oem filters , from simple age and time ?
Call out # 23217A is the filter in-tank mesh sock screen element , MUST replace when doing / did pump years ago ?
Thanks for the replies. Did some more checking and the fuel pump was the culprit. Locked up! When I pulled it, the screen mesh, which I had replaced, had come loose. Obviously, I didn’t do a good job of replacing it. Likely knocked it loose when putting the fuel pump into the tank.
