Found my FSMs, yay!
On EC-7 of the FSM, for the charcoal canister check, it says to blow "low pressure" compressed air into the tank pipe to test proper function of the check valve. I presume this is supposed to be just enough pressure to move the check valve ball when it's operating properly. My question is, what pressure should that be? My gas tank was getting pretty pressurized when the check valve failed (fortunately though none of the seams ruptured), so I'm going to try the Chemtool trick and see if I can free up the valve. Obviously I don't want to blow too much pressure into it and cause any damage, but if I can free it up and verify that it's functioning properly afterwards, that'd be great.
