Hello LC FAM. I am planning to do a body off restoration and custom build out to my 88 FJ62. After making a list of all that needs to be done, I believe it will be a much more efficient approach to remove the body.
Build out plan includes (short list)
A new lifted suspension, OME 2.5" Full kit. With 33" tires.
Replacing all bushings, including body mount bushings.
Swapping out the oem 4.11 gears for 4.88's, and installing front and back air lockers
Custom exhaust, front to back, including performance headers and CAT delete.
Keeping the original 6 pack, if I can get it running worth a darn! De-Smogged.
Swapping out the auto transmission for a manual 5 speed, H55f
Adding a tow package
In addition to all this, a few other points below lead me to believe taking the body off is the way to go.
1) Frame has some rust damage. From what I can see, most of the rust is limited to surface damage. However, the back end, behind the shackle mounts, has meaningful damage that will have to be repaired in a structural way.
2) My plan to swap in an H55f manual five speed will require the transmission cross member to be moved.
Most of this work, I can do myself. However, I have never taken the body off a vehicle before. Any tips or tricks to removing the body from an FJ62??
Thanks all!
Thanks all!
