fj62, bj60, fj60, hj60, bj40 parts (1 Viewer)
east coast Canada
clearing out more stuff
PayPal only, shipping on your dime.
located Nova Scotia Canada postal code b2w6a1
fj62 a/c compressor, worked perfect when removed and was immediatly sealed upon removal. $50............pending
fj62 a/c amplifier $25
fj62 a/c compressor mount, $25
fj62 idler pulley for a/c ? $10
60 series rear marker lamp assy $15 ea
60 series front marker lens $5 ea
KN filters, one for 60 series and 0ne for 62 series $10 ea................ 62 pending
heater fan/motor assy, $25
fj60 wiper motor assy(not shown), $25
injector cooling fan and sensor $30
OEM bj60(fj60?) am/fm radio and cassette deck and mounting brackets $75
BJ60 stuff
bj60 air filter housing top $25 (missing sealing ring for filter)
either rubber hose for air filter $10
steel tube that goes on valve cover for air $10
heater valve $10
engine mounts $10 ea
throttle pedal with firewall bellows/seal $20 ea
bj60 throttle cable (bit of insulation missing) $25
bj60 pivot assy for throttle cable that monts on firewall $10
push pull rod for throttle $10 each
bj60 heater tube that runs down the side of the valve cover $10
HJ60
alt mount $10
24 volt alternator with vacuum pump, function when removed $100 (not pictured)
BJ40 24 volt
vacuum pump off bj40 $10............sold
flasher relay for signal lights $15...........sold
starter relay $15 ..............sold
starter for BJ40 $100
:cheers:
Daryl
Interested in the starter and flasher relays but need to confirm fitment for my application. Got any part numbers off them?
Also the vac pump is the one that mounts behind the alternator correct? Interested too.
more pics
Bj60 BJ70 super glow stuff
pre heater timer (box) $50
any other relay $10
connector bars/resistors $25 ea
Daryl
see attached pics:beer:
part num for start relay illedgible
I just confirmed that the 24v BJ40 starter & flasher relays work for my application so I'll take those. I might as well take the vac pump too. Do you take email bank transfers seeing as both of us are in Canada? Plus it''ll be free for you as PayPal will charge you a fee....more economical. Let me know the shipping fees to M1S 3R3 Toronto, ON please.
Cheers,
Noel
Cheers,
Noel
yes i do bank email xfers, good idea, forgot about that feature!
I will get a quote to you today or tomorrow, Canada Post
Daryl
OK as in my other parts posting I am going to give it a day or so. This way I can do all the shipping quotes in one trip, less time consuming for me.
thanks for your understanding
:beer::beer:
Daryl
I'll take the Ac compressor and the 60 K&N filter
Shipping to 92675.
Thanks
PM me with total and PayPal info
farmerzoe said:
I will take 24 volt radio if available, any other 24 volt bj-40 items
It is a 12 volt radio.
Daryl
Splangy said:
The 60 series K&N is for a diesel right? If so, I'll also take that if Bob doesn't want it.
I have one for a bj60 and one for a fj62. But they will fit either rig. The fj62 one is larger outside diameter but the same otherwise.
Daryl
PM's sent
Daryl
Ttt for today
i see there is an inner transfer case shift boot, is that from a 40 or a 60, if its a 40 please PM me!:)
thanks
-Garrett
