clearing out more stuff
PayPal only, shipping on your dime.
located Nova Scotia Canada postal code b2w6a1
fj62 a/c compressor, worked perfect when removed and was immediatly sealed upon removal. $50............pending
fj62 a/c amplifier $25
fj62 a/c compressor mount, $25
fj62 idler pulley for a/c ? $10
60 series rear marker lamp assy $15 ea
60 series front marker lens $5 ea
KN filters, one for 60 series and 0ne for 62 series $10 ea................ 62 pending
heater fan/motor assy, $25
fj60 wiper motor assy(not shown), $25
injector cooling fan and sensor $30
OEM bj60(fj60?) am/fm radio and cassette deck and mounting brackets $75
BJ60 stuff
bj60 air filter housing top $25 (missing sealing ring for filter)
either rubber hose for air filter $10
steel tube that goes on valve cover for air $10
heater valve $10
engine mounts $10 ea
throttle pedal with firewall bellows/seal $20 ea
bj60 throttle cable (bit of insulation missing) $25
bj60 pivot assy for throttle cable that monts on firewall $10
push pull rod for throttle $10 each
bj60 heater tube that runs down the side of the valve cover $10
HJ60
alt mount $10
24 volt alternator with vacuum pump, function when removed $100 (not pictured)
BJ40 24 volt
vacuum pump off bj40 $10............sold
flasher relay for signal lights $15...........sold
starter relay $15 ..............sold
starter for BJ40 $100
Daryl
BJ60 stuff
heater valve $10
HJ60
alt mount $10
BJ40 24 volt
Daryl
