FJ62 auto "slipping"
Northern Colorado
My friend has an 89 FJ62, and the tranny seems to "slip" every so often...for lack of better word..."slip" like on a standard when your clutch is going out. The tranny works fine over 90% of the time.
What is causing the slipping? Torque converter??
I'll be interested in any replies as well. Mine "slips" as well, but only when very cold. After it warms up a few minutes it drives normally, but on a cold morning it won't go out of first, instead of shifting up the engine just revs until I back off the throttle. Once the engine reaches operating temps, everything is back to normal. ???
I've encountered the same behavior in my '88 FJ62. I've checked the tranny fluid level and everything is OK. I've had this truck a couple of years now, and this seems to be "normal" when the temperatures drop. I was out on a snowshoe trip last winter and had to allow the truck to idle for a few minutes before I was able to get purchase on the transmission. Again, once warmed up a bit, the tranny seemed to operate perfect. I've decided that this is just another nuance of owning an '88 LC.
If anyone knows the cause (or a cheap fix), I'd be interested. Thanks!
It's not normal. My A440F doesn;t do that and it has 300,000 miles on it, with a 30,000 mile torque converter though. The tranny is supposed to slip until you reach 4th gear or 40 MPH (or somerthing like that) But you should not hear the RPMs go up sharply then come back down either when you give it gas or in between shifts. Good Luck.
Exactly what my 89 did several years ago - ended up w/ a rebuild. Damn near left the wife stranded (not a good thing). Rebuild consisnted of new torque converter, clutch packs, valve body - the works. Most likely it's one of the valves sticking in the valve body. You can try an ATF replacment or flush (some here don't recommend the flush) and see if that helps. Keep in mind that you can only replace the ATF in the tranny and not the torque converter - to get the fluids really clean you'll need to do multiple replacments to gradually get most of the old ATF out of the t/c.
First, get on over to the 3FE list. Lots of auto tranny posts in the archives, and a resident expert on all things A440F. Ask for Rodney...
Your symptoms sound almost exactly like mine were. Has the ATF temp light ever come on while on the highway or in hot weather?
Next, do a FULL tranny service. Drain, inspect the pan and magnets, clean or replace the filter.
Put it all back together with new gaskets.
Do a PASSIVE full tranny flush with new syn. ATF
Adjust your kickdown cable.
You have the FSM, right?
If this doesn't improve the symptoms, you may be a candidate for a Extreme Valve Body from Slee Off Road. Sounds like your valve body is blocked or worn out. UNLESS your pan has alot of metal, or the screen is blocked with fibrous material. Then, you may be a candidate for a total rebuilt Extreme tranny from Slee. Or a H55.
The EVB fixed me right up (knock on wood). Replace your kickdown cable while the VB is out. I didn't, and now I need to. D'oh!
Try the maintenance and TLC first. This has made improvements for others. Try this and report your findings on the 3FE and here.
Good luck,
Mitch
At the very minimum you need to replace the filter screen inside the tranny. This problem is well known and documented on the 3FE list.
http://autos.groups.yahoo.com/group/3FE/
You can search the 3FE archives at
http://www.birfield.com/modules.php?name=Archives&p=/archives/html/3FE/
Search on trans flush or transmission filter or transmission slipping etc. The A440F worldwide guru is on the list and can help diagnose your particular problem. He is Rodney from Extreme Transmissions in Australia. Slee off road is now carrying his extreme valve body and complete A440F transmisison.
You can find the instructions for flushing the tranny using its own ATF pump and you can check the flow rate etc. Does not sound difficult and several on 3FE have done it.
I toasted 2 A440F's in my 88 FJ62 before converting it to the H55F five speed. The first had symptoms you guys are seeing then it failed entirely. I bought on from a guy who swapped in a SBC vortec and Chevy tranny. It had been rebuilt and had like 4k miles on it. It died less than 1k miles after I installed it.
We did not know about Rodney at the time or I might have gone with his extreme transmission. He can change the shift points and converter lock up. In fact his units now can lock up in 3rd gear! Several 3FE listers have his extreme valve body and one bought his whole transmission. I paid $3200 for the parts to convert to the H55F with me doing the labor. I could have purchased his extreme A440F for about $2700 saving $500. That being said, the H55F is the best modification you can do to a FJ62.
Dunbar
Ha,
Mitch you beat me to it.
Dunbar
I was discussing A440Fs with a reputable Toyota mechanic and his comment was that replacing the torque converter usually solves most A440F problems - a total rebuild is rarely needed.
