My 61 has been running for about six months now, but it is having some issues. It is a basic 2F with no smog equipment other than the EGR system. From the factory it had a points dissy but I replaced it with a USA big cap.
Issue #1. Rough idle
This is kind of a weird one. When it is first started up the idle is pretty good but after running at high throttle it gets really rough. Today when I pulled off the interstate after doing 100-105 for 45min or so it died when I clutched in. It restarted fine though and I left the choke out a bit to keep it idling. After sitting for a couple hours it restarted and idled fine until I drove for a while, at which point it got bad again. I checked the float level while it was running rough and it was halfway in the sight-glass. My next thought was vac leak so I did the carb-cleaner test all around the manifold and vac lines but the idle didn't change. Tomorrow I'm gonna stop by an auto parts store and buy a vac gauge.
Issue #2. Running rich
The last time I was convoying with a group the person behind me said my exhaust smelled heavy of fuel. At idle (before the idle went bad) it smelled fine.
Any ideas would be much appreciated.
Thanks!
Thanks!
