fj60
I am trying to find an elective fan for radiator. I have tried several and they do not cover the entire radiator so it runs hot. Does anybody have a recommendation??
Excuse my smart phone I am looking for recommendations for an electric radiator fan.
Run the factory clutch fan and shroud. You should have zero issues with cooling using the stock set-up.
If you are having overheating issues it may be your radiator. Give us some more details about how you came to your diagnosis.
I've got twin thermo's on mine, but it's also a v8 efi engine...
I've had it out on the dunes, and crawling up in the bush, with not problems on warm days.
But as stated, make sure your rad is clean, maybe a flush would help. But yea, stock fan and shroud should work no problems.
I wanted mine to clean up the engine bay, and also stop the huge wind noise a clutch fan makes. My ECU turns the fans on and off at set temperatures.
These are what I have, from an EL Ford Falcon, picked them up for $20
No idea if you can get them over there or not though.
Had to cut the shroud down abit, but they have a pretty good seal on the radiator.
This is how they look in my bay.
I can grab closer pics for you if it would help.
Yep! I have yet to hear of an electric fan that can pull the CFMs of one powered by a 6 cyl engine.
