Hopped in the 60 after work today to go home. Pulled the choke to one notch out and started it. It started, grumbled a bit and died.
Pumped gas, tried it agian. Same result.
Pushed choke all the way in, pumped gas a lot. Tried to start it, motor cranks- but doesnt turn over.
I have gas in the fuel filter, but can't check if the pump is working. Also don't know if I'm actually getting spark.
How do I check to see if I'm getting spark, or fuel?
As much as I tried over and over to pump the gas I never smelled gas like I think I should have. I even tried pumping it like 10 times just to see if I was getting gas. My thinking is (because I can't smell the gas getting to the carb) that the fuel pump is bad.
An old jeep wagoneer I used to drive was carb'd I think. If I pumped the gas more than tree times it'd reak of gas smell. The 60 never did, no matter how much I pumped the pedal.
Is it common for the pump to just fail like that?
