4Cruisers
So just pulled the valve cover to adjust the valves and have a mushroomed push rod on the intake valve for cylinder 3. Do I need to pull the head to replace the pushrod. Should I replace the lifter as well?
I had the same thing happen on my '84 FJ60. I was able to buy a good used $5 pushrod locally at BTB Products in Henderson, NV. You don't need to pull the head, just temporarily loosen the rocker arm assembly enough so that you can pull the old pushrod out and slide a replacement back in.Also I found the cap for the pushrod on top of the cylinder head but also found this clip.
