FJ60 upper Shock mount
Walnut Creek, CA
The upper front shock mounts are cracked on my 1987 FJ60. Are these replaceable? What are the part numbers?
If they are replaceable how?
I don't see how to remove the mounts. Are the bolts pressed in?
Anyone have any ideas?
Thanks,
Dave
I just finished a SOA on mine. I wanted longer shocks so I removed my uppers and moved them up about two inches (And gussetts). I used a grinder (High quality) to remove the bolt heads. They will not come off.
I suggest you either upgrade to shock hoops (Dual upper mounts) or just have a welder fix up your old ones where they are. Troy
