Have possible engine , 4 spd tranny, xfer case from 85 fj60. Would this bolt in a 73 fj40..... I mean to the engine mounts.. I cannot weld:whoops: so I would want to use my original engine/tranny mounts. I can buy different drive shafts. Thanks guys if no answer will search but i am at work w limited time today.
Nathan I think this will bolt in, (some others here can tell you for sure) you will need to add an e-brake to your back calipers with a disc brake kit or something. I believe the main reason I didn't use an fj-60 trnas and xfer was the fact that addding the e-brake to the rear of the xfer would have created clearance issues with the rear crossmember. GL junker
You also need to add a crossmember between the frame rails to support the transmission. You will notice that the bellhousing doesnt have provision for mounts... I think you can swap to the earlier 4sp bellhousing but things got so complex that I rustled up a '76 for a donor, and I might unload the '83 engine/trans/transfer even though much of it is better gear....
The engine will, then reuse your 3 speed bellhousing tranny and transfer for an actual bolt in. Otherwise as others noted above you will have mods to make.
Better settup would be 75-79 40 series tranny and transfer, so you get the original transfer e-brake. But any conversion from the 3 speed to the 4 speed in a 73 will mean driveshaft lenght changes, as the trannies are different lengths.
Also, I don't know if the engine mounts, on the engine block itself are correct between a 60 and 40 chassis, may need to get 2F engine brackets from a 40. However the brackets on the frame will stay the same.
Sounds like I should buy engine.... if a good price. I have a 4 speed tranny w 3speed xfer case on it. Sounds like i would need a bellhousing,clutch assembly and drive shafts?? Owner says smokes at start-up then goes away 200,000 miles and is still running. I will start it when I get there. Any suggestions on price i should offer. i was thinking 200-400
