fj60 steering wheel into fj40? (1 Viewer)
Portland, Oregon
i am doing power steering mod. saginaw. my 17 in. stering wheel has got to go. i picked up a column plus linkage out of a fj60. any suggestions?:steer:
Meridian,TEXAS
If your just going to swap out the wheel, remove the 2 signal cancel pins on the 40 and install them on the 60, as it has none....
is anyone selling bolt on aftermarket steering wheels for the 40?
Portland, Oregon
Thanks for the pics. I am 4 inches to far forward after my first adjustment in the pillow bearing. i see that the saganaw may need to be in place to do the final mearusrement? I am right there, just a few more details.
Hugh Heifer
Chasing the Beast
Rome, GA
I took an old Grant out of mine and replaced it with a blue one from an FJ 60. The grant was a bit small for my taste and 13"....plus it looked pink from fading.
Meridian,TEXAS
I do believe the FJ62 wheel added a nice touch..............:steer:
Added the 2 pins so to retain turn cancel function................:wrench:
This is not finished yet, but I am mking a steering column.
Used a 40 steering wheel from a 72, bottom of the a 60 steering column .
The shaft inside is made from the 40 shaft and the 60 shaft with upper and lower bearings. It will fit into a 40, but I am making it for something else.
I will use a shaft from a mini truck to go from the steering cloumn to the sag box with a the slip yoke either from the 60 or the mini depending on what I find in the junk yard this week.
So you can make anything, and the 60 should have a lot of joints you can use.
