FJ60 starter is the best thing ever!
Breckenridge, CO
So I just swapped in a FJ60 gear reduction starter, and it makes a huge difference. I think it starts my engine quicker and sounds a lot more solid. Basically bolts right in, I did however have to extend 1 wire a few inches.
Best part it was only $35 from TAP through ebay. Everybody should do this...
There's also a little bit on this in the FAQ...
Cruiserdrew
On the way there
Sacramento, CA
I just did the same. I got mine from someone on Mud, then put in a new set of contacts and plunger. Good as new.
hyrum Utah.
If anyone needs a used one, I have one off my 60 that I will send for the cost of shipping only. I live at zip 84319 in Northern Utah.
Cruiserdrew
On the way there
Sacramento, CA
I'll take it! A spare is always good.
san pancho, ca
High-Torque starters are a GREAT mod...
Having the option of utilizing your starter to get you over an obstacle (when necessary) is always good.
used mine on Vrock (going up Cadillac leaving the springs) 2yrs ago :D
North Pole, AK
I love mine as well. It helps having a parts 60 around. Next on the list is a "big top" dizzy from the 60 to the 40. We will see how that goes. I just picked up a brand new Downey header and gear reduction starter for $100 yesterday for the parts stockpile. Woo Hoo
TK
Charlotte North Carolina
nice
i just bought one a few weeks ago from autoparts warehouse too but i havent installed it yet. Looking forward to it now.
so you said you just had to extend a wire a bit?
Cruiserdrew
On the way there
Sacramento, CA
I didn't even have to do that. Even the wire fitting is the same from my 76 harness to the solenoid side of the starter. It'a very clean factory fit. I did run a new main starter wire just to beef it up and remade the ground as well.
I used 4 gauge Marine cable, with marine heat shrink. Some use 2 gauge but even the 4 gauge is stouter than the factory wiring.
