- Joined
- Jun 30, 2015
- Messages
- 147
Hooking up starter in 1986 FJ60 w/ stock 2F. Connected thick black cable from battery to the bottom front of starter and also the smaller one for what i presume is the starter relay. I still have to connect about a 12" black cable with yellow stripe that I recall being attached to the starter as a ground. Does this attach to one of the starter housing bolts where it joins bell housing? I had every piece off this rig and reaching my limits of memory recall. Where does the other end of this ground attach to body or frame? I've got the ground up front from battery going to passenger side motor mount, and the one from engine block attaching top of firewall. but i can't remember where this other one goes.
