Fj60 stalls when I come to a stop or slow down. (1 Viewer)
Bend, Or.
Fj60 stalls when I come to a stop or slow down. Fuel pump failing or filter??
Any quick ideas?? thanks
Bend, Or.
2f with a Weber carb. Would that still apply? What does it look like?? Thanks
If I'm on the gas, it feels as though it cuts in and out like theres achoke on the fuel line.
Spike Strip
Goblin Mode Activated
Lost Angeles
No, won't apply - So never mind, since I know nothing 'bout Webbers.
Incidentally, you might want to change your sig line from "bone stock" FJ60, so no confusion ...
Good luck.
Bend, Or.
Well, thanks anyway. Yep it won't be stock + webber for much longer.
Austin, Texas
Does it idle at all? Do you need the choke open for it to idle? If yes, a little or a lot? Change fuel filter regardless to eliminate it as a cause.....$5 or so.
Sent from my rotary phone using IH8MUD
Just solved the same problem with a quick carb rebuild. It doesn't take much to stop up the 1st or 2nd Slow Jets. Just cleaned the jets because they were not in the rebuild kit. Works GREAT NOw. And, yes replace the fuel filter!
