After a break in and theft of my FJ60, I decided to take its security a little more seriously (apparently all the rust wasn't cutting it).
Here's an option for a keyed hood lock on an FJ60 (1985 shown below). When locked, this prevents the factory hood release handle from opening the hood. There's also an option to integrate a kill switch on your system of choice, which I plan to do but haven't gotten to yet.
The base of the system is this "Hornet 567T" cable hood lock, 7ft long. I found mine on ebay.
There's an example of how this type of lock is designed to work and be installed here:
I didn't want to install the bracket they provided on the hood itself, so I decided to use the pin to block the factory cable from operating the mechanism that releases the hood. That required drilling a hole in the hood latch assembly.
The pic below shows the locking pin through the newly drilled hole. The latch is shown in the "hood closed" position. The red arrow shows where the factory hood release cable attaches and direction of pull when opening the hood. With the pin in the "locked" position, the factory hood release can't rotate the arm in order to release the hood. (The rubber band is there for testing rather than the stronger factory spring.)
I fabricated (roughly) a couple of brackets out of 1/8" x 1" aluminum angle to help guide the pin and hold the cable end. Here's everything mounted under the hood:
Note the bracket on the right requires a new hole in the radiator support piece. Pin is shown in the locked position.
