I replaced my clutch, pilot and throwout bearings last December. At the time, I thought I should rebuild the transfer case with 160,000 miles, but I decided not to. I was having some driveline vibration before the clutch replacement when I was starting out in gear, plus the typical throwout bearing whine.
The new clutch and parts seemed to help that for a while, but gradually I am having a harder time shifting between gears and into gear from neutral. Sometomes the gears grind if I don't wait long enough.
The driveline vibration is also coming back- mostly when going from 0-5 mph in 1st or second gear.
I did have some minor play in the rear pinion, so I tightened it up temporarily with no change in vibration.
I have purchased a used T-case and 4 speed tranny. I am planning on rebuilding both of them, but wanted to see what input everyone here had.
I am not ready to spend an additional $2K on a 5 speed right now. I mostly drive in town, so the 4 speed works for me and my wallet.
The good thing about this project is with the replacement tranny and t-case, I can take my time on the rebuild and take it to Butch or someone else if I get in over my head.
Questions:
1. Is there a way to tell if my replacement tranny needs to be rebuilt with it off the truck?
2. If the synchros are worn, can replacements be purchased?
3. How do I know if I need needle bearings for the T-case? Marlin Crawler has them but Kurt at cruiseroutfitters doesn't show them on his web site.
4. I plan to have the driveshafts balanced. Is there a way to tell if the u-joints are bad or not? At 160,000 miles, should I just replace them anyways?
5. Everyone says buy OEM Toyota U-joints. Do the ones that Marlin or Kurt have compare, or do they need to come from Toyota?
6. Any other words of advice?
Questions:
