FJ60 rear ARB question
Discussion in '60-Series Wagons' started by Cruisergreg, Mar 27, 2004.
  1. Cruisergreg
    Cruisergreg
    1,846
    2
    Jul 20, 2003
    Does the ARB locker reuse the stock cross shaft retaining pin or is another supplied with the kit? :mad:
  2. beanz2
    beanz2 Moderator
    2,124
    6
    Nov 16, 2002
    Stock cross shaft IIRC. Been a long time since I had an ARB.
    Dave
  3. Rock_Hugger
    Rock_Hugger
    383
    12
    Mar 27, 2003
    CA
    The ARB has all new stuff, nothing reused from stock carrier.
  4. 60wag
    60wag SILVER Star
    1,926
    40
    Jun 25, 2003
    Boulder, CO
    The retaining pin was missing from my ARB kit. Call ARB and they'll send you one for free.
  5. Poser
    Poser Oh...Durka Durka Durka. s-Moderator Supporting Vendor
    20,305
    Media:
    17
    Albums:
    1
    621
    Oct 1, 2003
    MN
    cruisergreg-
    Do you have any install instructions with this? There will be a parts diagram showing everything that you should have. You will need a funny little threaded tool to insert the pin, and make sure that it is seated, check this a couple times, as to not have anything come undone and cause problems later.
    Talk with Tim in tech at ARB- 888 427 2872, he will be able to take care of you.
    Good luck!
    -Steve
