fj60 power steering pump removal
on the ice, wyoming
Website
www.pointyhatdesigns.com
looks like i need to remove the bracket, as the one back bolt is too close to the manifold to remove. I can only see two bolts one below the brace parallel to the manifold and one in front. Ive removed the one under the brace and loosened the other one and its not moving. Do I need to get out the BFH or am i missing something?
There are three bolts on the same side of the mainfold. One up high by the manifold, two below. Then there is the bolt on the front of the block. Remove those four , then remove the two just under the P/S pump which are on the Air pump bracket.
