FJ60 Portal Axle Swap (1 Viewer)
Hey, Doing some research into portal axles for my 1983 FJ60. I have done a budget lift with stock spring packs. I added 4 springs to the back and 2 springs to the front, and rancho shocks all around. (not too shabby for a few inches, 33" tires, and a $60 lift!) Now I want more ground clearance without raising my center of gravity. I understand that Portal Axles will give me about 5" more at the differential, as well as coming with lockers front and rear and reduction boxes at the wheel! Hot Damn!
Now I am looking into putting it on Portal Axles out of a Unimog or Volvo or something. Anyone know of what setup is best? I am looking to do as little cutting and welding as possible, and would like to be able to do 60 mph on the highway when finished. I am considering either Unimog 404's or Volvo axles out of a C303. Any suggestions are appreciated. I want to have a good plan before I start buying stuff.
-Don
Oh yeah, and I still want to keep this on a 'reasonable' budget. This is my 'Budget Cruiser' project, and I've managed to build a sick truck for less than $5,000.
The Greatland
Website
www.facebook.com
IIRC from the last time I looked at prices, plan on spending that much again for those axles. :(
You'll have to run some fairly tall tires to see a comfortable 60 mph cruise speed with the gearing in Volvos or Mogs.
The truck will go up. So will CG.
Mark...
Yeah, truck up cg up, makes sense. seems like less than with big lift springs? I thought about dual t cases, or an overdrive box. I hear that some cruisers came equipped with a stock 'Brownie box'. I can't remember if it is a gear reduction or overdrive box.
I have a 4 speed from a 79 fj40 and was thinking about looking into trading it for some of the parts.
by the way, I am a landscaper in the Seattle area and will do trade work for Cruiser parts / work on my cruiser.
pm me if you are interested.
Abbeville, SC
If you are on a budget a SOA would make alot more sense for you. Portals would probably be a great deal at $5K for just the axles. Not all the fab work, etc that you will have to do or have done.
Search on here and pirate for portal's you should find more info than you want to scare you if you want this to be a budget build.
But hey if you do it I will certainly follow the thread :) Nothing like watching people spend the $ I dotn have on thier cruiser.
The Greatland
Website
www.facebook.com
You realize that dual T/Cs will give you steeper gearing, not taller, right. No Cruisers came stock with an overdrive unit installed. The "Brownie" is basically the same as a Ranger O/D. The Ranger is conversion sometimes done in conjunction with a V8 swap.
A '79 fourspeed has a value of a couple hundred dollars when swapping.
Mark...
lowenbrau
Rockyview County AB
Mark...
Rob of Exaxt axle used a 203 reduction section and a "halfer" rather than a "doubler" to make his Mog equipped Blazer run on the highway.
This project is a non starter for someone who has a small budget and doesn't want to weld. The Volvo axles are as close to bolt in as you can get but with 7.5:1 it'll take a lot of $ to speed the truck up to highway speeds.
calgary
i think the highest geared axle you can get is 5.99 in the volvos, but they are the closest to an easy install, so youd need 40" tires to have a close to stock ratio.
But ive seen these axles go for $4k and under for a pair.
TiredIron in the 80's section did this swap and was selling his rig at one point. he also has a build up to give you an idea of whats involved.
New Kent, VA
You do realize how friggen big that is gonna be right?
Mace
rock scientist..
Staff member
s-Moderator
Las Vegas
Somewhere around 40" tires would be perfect.
Volvo portals are the best choice for wht you are considering but it is gonna cost a lot more than 5K..
Heck, you will have over 2K in rims and tires alone..
calgary
consider $: gears front+back, arb lockers front and back,longfields, install kit and bearings, compressor, Upgrade front brakes, upgrade rear brakes, big ass lift springs or SOA.
Compare to the price of volvo axels, where you gain 5ish" clearance at diffs and probally dont need taller springs. Add up the $ to upgrade your stock axels and then consider pros and cons of going portals from the start.
Tires and rims are going to be $$, but if your planning on lifting and running larger rubber anyways...
Also with a 40" tire your gonna want to either go high enough to clear em with more lift, or chop a bit of sheet metal.
Heber City, UT
You might look at the portal axles on a pinzgauer also. Two to ones at each wheel.
DC
I think the mog axles are offset in the rear as well. If I remember from other posts, you will need to swap Transfer cases as well. Is the pumpkin up front in about the right spot too (or left spot I suppose..)??
Mace
rock scientist..
Staff member
s-Moderator
Las Vegas
mogs are more centered..
Alaska
I was seriously considering this with a 91-92 FJ80 a la tired-iron but came across the 60 instead.
Anyways figure $4k for a set of axles plus shipping then the only real hard part is the drivelines and the wheels. That's assuming you are ok with the Volvo drum brakes, it gets pretty spendy (though wheel selection gets better) when you convert to disks...
Here is the only cruiser I am aware of on portals, who later pulled them off for a more highway friendly setup IIRC:
https://forum.ih8mud.com/showthread.php?t=65178&highlight=c303
http://www.pirate4x4.com/forum/showthread.php?t=214232
I’m sure there are others though.
I was running the numbers pretty hard and it was a “little” more expensive for the portals than building up cruiser axles and getting 6” of lift in an 80. I bet it would be a lot more $ for portals in a 60 though…
calgary
i believe the diff is on the proper side on the volvo axels to match stock drivetrain, whereas the mog axles are centered, so would better match a chev powertrain.
The volvo's have cable lockers, if you compare selectable locker that comes with the volvo to getting a set on a cruiser (im guessing just under $1500) then what youre paying for volvo axels seems a little less. add 5 or 6 hunred for gears, the same again for longfields, the same again for rear disc conversion, and up to$1K for 5 inch lift to match the volvos, and a couple hundred for 4runner brakes in the front, it seems pretty close to match what you get with volvo. aside from the extra 5" clearance at the diff.
however it looks like disc conversion is pricey on the volvos.
It seems like the best place to get a set of volvos is to keep checking pirate for sale axles sectionn and i think portal tek might have a set laying around, does anyone else know where to buy c303 axles??
