I'm writing this thread to simply thank the stars for aligning and me not losing my sanity while changing out the p/s pump yesterday.
Life of a truck near the beach.....
My 2F has always been a squeaky machine and I felt the alternator and p/s pump were getting affected by the salt air. The bearings were making some joyous squeals... or at least I noticed them.
Well about 100 miles ago somehow my old p/s pump had the pulley come loose and was seriously wobbling on the shaft. I felt that either it was going to seize... or completely wobble off. Luckily I found a local FJ60 being parted and scored its p/s pump and alternator and other misc. bits for $100.
So starting at 2pm on Sunday after finally motivating to get going I removed the alternator which was a piece of cake and then moved on to the p/s pump. Holy schmoly is it a PITA to get at all the bolts holding on the p/s bracket to the block with all the smog stuff in the way and other junk. After manipulating my hands/arms thru the labyrinth of accessories and lots of cursing, a few lagers, some grease, scrapes, dropped tools, draining fluid etc... I finally got the pump off. This was supposed to be the easy part..... yeah right!
A short trip to Kragen for brake cleaner, p/s fluid, and beef jerkey and back to the contortionism.
So I finally grab the replacement p/s pump and get to gettin'.
Man is it a PITA to get these bolts to thread in place. So out comes the 500W halogen on the stand as it is gettin dark... another hour of cursing, using the prybar, and I button it all back together. Check for belt alignment/tension and fill up the reservoir with fresh p/s fluid. Start it up and it simply purrs..... No squeaking and actually is as quiet as it has ever been.
I'm happy it works again and it wasn't too bad once completed. I only spent 30 mins in the shower shrubbing my arms/hands/nails "clean(er)."
It looks like a cat attacked my forearm with all the scratches.
Hopefully it runs for a long time to come now without any problems. Only 135K on the clock.
Just wanted to share my frustration and then happiness
